connector to link different diameter tubing?
Dear All,
I have a plane in which I installed a pneumatic gear retract. I thus equipped the filling tubing onboard the plane with a fill valve. The problem is that the tubing diameter of my airpump is not the same as that of the filling tubing onboard the plane, and I can't find a connector that allows the connection of tubing with different diameter...
Does someone know where I could find such connectors?
I thank you a lot in advance!
Nico
Nico
RE: connector to link different diameter tubing?
Hi there from Toledo
Try the various car parts stores. The often have repair parts for vacuum tubing and wind shield washer fluid tubing. I have seen size change fittings there. Also check with Robart, Rhom air and the other retract mfgrs., maybe Dubro too.
ciao -rjf
ciao -rjf
