prop nut [ alloy ]
prop nut [ alloy ]
guys from Australia, would you know where i can buy an alloy prop nut [ not the Dubro type ] i think these could be a Thunder Tiger brand there machined from aluminium hex bar so you can use either a spanner or rod to do up or undo. thanks. i need it for my Thunder Tiger pro 46 engine.
My Feedback: (85)
RE: prop nut [ alloy ]
Great Planes makes them in either Aluminum or Brass. They take a 7/8' 22mm wrench. cannot remember if they have the hole drilled in them for the rod though. You will need the 1/4-28 version. Higley makes them also as stated in an earlier post. Mecoa also makes them.
Just checked on tower's website. The Great Planes part# is GPMQ4630 and it is showing the 7/8" 22MM spanner plus the hole for the rod.
