Reload this Page >
Fuel pump on the fuel jug setup (electric or manual).
Reply
Old 06-01-2003, 01:45 PM
ny_rc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fuel pump on the fuel jug setup (electric or manual).
Electric or manual. I saw some guys have fuel pump screwd on the jag (where the top goes). Some others have manual pump on the metal piece on the side. Unfortunately they don't know where to get them now.
Where I can get this setup or at least who makes it?
Thanks.
I'm fed up with remote electric pump. 3 of them (Magnum crap) got broken in a year.
ny_rc is offline
Old 06-01-2003, 02:13 PM
Dsegal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just hold my fuel pump in one hand and crank with the other hand. Works fine.
Dave Segal
Dsegal is offline
Old 06-01-2003, 08:07 PM
ny_rc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is one big pump !
How reliable is it ?
ny_rc is offline
Old 06-02-2003, 10:51 AM
dant-RCU
dant-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Slimline Products makes both an electric pump that screws to the top of the fuel jug and a mechanical that also mounts to the top of the jug on the fuel cap.
I have used them both - both work just fine.
Here is their link:
http://www.slimlineproducts.com/
Dan
dant-RCU is offline
Old 06-02-2003, 12:06 PM
Dsegal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
> How reliable is it ?<
The Six-Shooter is probably the most reliable pump on the market. It is just a crank that revolves pressing two plastic lobes along a piece of plastic tubing to force the fuel. But I hated its awkward mounting to the jug and the bumpy way it felt when cranking. I went for a smaller geared hand pump.
Dave Segal
Dsegal is offline
Old 06-02-2003, 01:59 PM
dickj
dickj's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fuel Pump
I have one each of the Slimline Electric Pumps that screw on the Plastic jug and one metal sealing cap that fit the plastic jug. I have used their electric for two years without any problems. I personnally like the cap and manual pump arrangement as there is no battery to lug around. Something you might want to consider: I purchased both types to fit the plastic jugs and then the fuel containers (Power Master) turned into metal gallon cans. I now have the wrong type and have to transfer the fuel to the old plastic jug. Slimline makes caps and pumps for the metal cans also. The wave of the future is metal due to EPA regs I am told. Their reliability is excellent. Here is the link for the two products, listed under Fuel Pumps. http://www.slimlineproducts.com/rc_plane_intro.htm
dickj is offline
Old 06-02-2003, 04:08 PM
ny_rc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks dickj !
That is exactly i'm looking for!
ny_rc is offline
Old 06-02-2003, 07:28 PM
Spaceclam
Spaceclam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
slimline makes the one you see on top, or baybe sullivan, i forgot. but i have had good luck with electric pumps. i guess some of them are crap, you get the smae one and it lasts longer than you do
Spaceclam is offline
Old 06-03-2003, 01:08 AM
david a
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use the Hanger 9 manual pump and I mounted it to the side of my flight box. Works fine. I have found that I get better service with less down time by keeping things simple.
david a is offline
Old 06-03-2003, 01:23 AM
Spaceclam
Spaceclam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my pump is really fast. it is electric, a hobbico mk III. it has not yet even degraded in it's performance, but is almot 3 years old. considering that a cheap electric pump is about $2 more than a good manual one, it's worth the extra bucks
Old 06-03-2003, 02:27 AM
glowplug
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I didn't have the same luck as SpaceClam with my Hobbico MK III electric pump. It lasted less than a year. I switched to a hand-held pump and hold it in my hand as Dsegal said.
Mike
glowplug is offline
Old 06-04-2003, 01:53 PM
Mustang Man-RCU
Mustang Man-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use a Six Shooter and have for the last five years. I do more flying than the average guy due to being retired. I have used the small, geared, manual pumps in the past ( Hobbico, Hangar 9, etc.) but they don't last as long as the Six Shooter. As for electric pumps, most of the guys I see using them spend more time trying to get them to work than they spend pumping fuel with them. I have my Six Shooter mounted to the side of my flight box next to the fuel jug. Works great for me.
Steve
Mustang Man-RCU is offline
Old 06-04-2003, 05:18 PM
scottrc
scottrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a manual pump but then it leaked. I now use a 12v windsheild washer pump motor that I bought at Wallmart for $9.
I went electric and will never go back to manual.
scottrc is offline
Old 06-05-2003, 01:25 PM
Mustang Man-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scottrc,
I've had 3 of those electric W/S washer pumps from WalMart and all packed it in after a month or two. I think the gears are plastic and get softened by the fuel but good luck with it.
Steve
Old 06-05-2003, 02:04 PM
visioneer_one
My Feedback: (506)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Re: Fuel Pump
I have a couple of Slimline's products. One of their Boxxer pumps mounted in my flight box, one of their aluminum fuel caps (also mounted in my flight box), and one of their M1 pump/cap combos.
The Boxxer is fairly new, and works fine. It does seem to have a low pumping rate, though... filling a 12 oz. tank seems to take over a minute even though I use a 14V battery in my box. (I need to time it.) My old manual Kavan pump was much faster.
I have one complaint with the M1. The Pump they supply has a plastic cranking handle which is attached to the plastic output shaft with a single screw through the center. This arrangement worked well for a while, until the handle started slipping on the shaft. I tried gluing the handle in place, shimming it with flat sheets of metal, etc. - no luck. I finally ended up drilling a pilot hole through the side of the handle & shaft and aded a single screw to lock them in place.
One other problem with the Slimline caps lies with the fuel nipples they supply. They corrode after being exposed to fuel and fail. The 'in' nipple on both the regular cap and the M1 cap have broken off inside the cap, and cannot be reteieved... I've switched the lines around and am still using the caps, but I expect them to fail at some point as well.
visioneer_one is offline
Old 06-05-2003, 04:00 PM
Banshee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been using a windshield washer pump for 2 years now and I haven't had a problem with it yet. Its survivability willl probably depend on what materials it is made of. I just make sure that I empty the pump out everytime that I use it. Plus I've only been using fuel with 5% nitro in it. I'm not sure how it would handle higher nitro content fuels in the long term.
Banshee is offline
Old 06-05-2003, 10:40 PM
Spaceclam
Spaceclam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you mean like 20%-50%?
Old 06-05-2003, 11:38 PM
Banshee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, fuels with that high of a nitro content could cause more damage to the pump.
Banshee is offline
Old 06-06-2003, 02:20 AM
Spaceclam
Spaceclam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well, i have run 20% through that pump for two years now. as long as you run it dry. but i like that windshield wather fluid pump idea. how come they don't make electric piston pumps?
Old 06-06-2003, 12:35 PM
silvercloud-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try looking at these www.jerseymodeler.com. Dean is a nice guy to deal with .
silvercloud-RCU is offline
Old 06-06-2003, 02:11 PM
Mustang Man-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Spaceclam, 1965 through 69 Ford vehicles used a piston type pump on their W/S washer. I dont know how well they would work for pumping fuel, they we're quite a thumper.
Steve
Old 06-06-2003, 10:49 PM
Spaceclam
Spaceclam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i was referring to smaller ones used for this hobby, considering that they would pump quite a bit faster.
