4.8volts or 6volt Rx
IL
Are all Rx capable of running 4.8 or 6 volts? Or just a select few. I have a Futaba FP-R127DF... Could I run 6 volts to get more out of my servos?
M
M
RE: 4.8volts or 6volt Rx
Perhaps a good question! I do not have a proven answer but have used 6 volts for years without any problem. No idea how long a servo should last on either voltage but don't believe 6v. will do any harm at all. Does improve torque and speed though.
My Feedback: (8)
I don't have experience yet going from 4.8 to 6 volts. I do have experience going from standard servos to digital sport servos, which are faster, have more power, and are more accurate. The difference is enough to have spoiled me, and I've got the near-bottom end of the digital sport servos!
MI
we started using 6 v , 15 to 20 years ago with no problems. I don't think we are getting much of a longer run time on them, they run the servo's faster and I think that draws mah down. I am used 2300 to 2500 Mah 6 volts battery's to get my run time.
The one reason I am using the 6volt now is the warnings on the 2.4 spectrum radio's and the need for the 6 volt battery's or so we are told, I have not seen proof of it, but I don't mind using them.
I have not lost a servo yet, to striped gears etc.
It would not hurt to check with your servo maker and ask about using 6v with thier servo's.
most...not all servos are rated for 6 volts...you'd have to either get the Tower catalog and look up your servo...or punch in your servo on line and see
My Feedback: (8)
ORIGINAL: jetmech05
PA
ORIGINAL: dignlivn
Are sub C size Rx pacs any better than AA size ?
Bob
Bob
My Feedback: (8)
ORIGINAL: w8ye
If you are a guy that flies from sun up to sun down like I sometimes do - Lipos cannot be quick field charged
I was burning over a half gallon a day in my .46! Well I'll still be burning over a half gallon a day, but probably 20 flights down to 8.
I'm getting 2300 or 2600mah lipos though, should last at least a few flights
My Feedback: (22)
IN
Seems a lot of Spektrum users are going to A123 batteries for Rx's. They make a 7v (no reg req'd), 1100mAh 2 cell that is about the same weight as a typical 5 cell NiCad, and can be charged at 5A for fast field topping without any harm to the battery. There is several threads on this if you search. I'm thinking about converting all of mine over down the road.
My Feedback: (16)
Nanophosphateâ„¢ lithium ion battery technology they are 3/6V but top off at 4.2V nominal 6.4-6.6 volts from 2 A123's
http://www.a123systems.com/products
http://www.batterystation.com/cr123a.htm
https://01836cd.netsolstores.com/ind...arch=GO&Page=1
