What is the ABSOLUTE BEST PROP
Reply
Old 06-03-2003, 01:44 AM
Spaceclam
Spaceclam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default What is the ABSOLUTE BEST PROP
i am an owner of a .91 four stroke engine. i am looking for the BEST 14x6 prop that is available, below $30. i am looking for thrust. noise is tolorable. i would also prefer less vibration, but it is not necessary
Spaceclam is offline
Old 06-03-2003, 12:29 PM
Gene Chernosky
My Feedback: (182)
Gene Chernosky's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Up to $30 for a 14x6 prop...
It's obvious that you are willing to spend more money on props than I am...hmmm...
I prefer APC ($12) and B-Y&O ($8) The B-Y&O is a wooden prop available from www.brodak.com
Of course there are the exotic brands, too...buy'em if you wonna.
Gene Chernosky is offline
Old 06-03-2003, 02:02 PM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Graupner!
MinnFlyer is offline
Old 06-03-2003, 02:05 PM
Charlie P.
Charlie P.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Depends on your application. Speed? Pattern? Scale? Sport?
I like APC as a general sport prop.
Charlie P. is offline
Old 06-03-2003, 04:11 PM
Spaceclam
Spaceclam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
unlimited vertical. here is why i am specifying 14x6: i can't go lower than that because my plane is rather heavy, and won't fly at those low speeds. plus, even if it didn't, i would look really stupid putt-puttin by at 20 mph. where would i find a graupner prop? i already have an apc on order.
Old 06-03-2003, 04:17 PM
beavertail
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think Graupner and APC make great props. But it really depends on your application.
beavertail is offline
Old 06-03-2003, 05:16 PM
Spaceclam
Spaceclam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
.60 size cap 232 with a .91 four stroke
Old 06-03-2003, 06:32 PM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What you want is a Graupner 13.5 x 8 They are outstanding on a 91 4-stroke, and will suit your Cap very well. (and under 10 bucks)
http://www.hobby-lobby.com/grprop.htm#2%20Blade
Old 06-03-2003, 06:52 PM
SMALLFLY-
My Feedback: (19)
SMALLFLY-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check out the bolly clubman 13.5 x 8 It has a swept tip similar to the apc but not as sharp.
If wood is OK try a zinger pro 14 x 6
SMALLFLY- is offline
Old 06-03-2003, 06:57 PM
Spaceclam
Spaceclam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
where would i find boly props? carbon fiber may be the answer. do any ofyou guiys know where to find a good carbon fiber prop?
Old 06-04-2003, 11:11 AM
SMALLFLY-
My Feedback: (19)
SMALLFLY-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default bolly props
http://www.bollyprops.com/clubmanintro.html
Not sure they make CF props that small. 18-6 is the smallest Ive run across in mejlik
I dont think that is what you want for a 91 anyway. CF props are usually a bit heavier and no prop on a 8+ lb plane with a 4 stroke 91 is going to turn it into a hovering machine
I have a 60 size Kaos that weighs about 7.75 lbs. It has good speed and very good vertical with the bolly clubman, but not unlimited with a saito 91
Old 06-04-2003, 12:01 PM
Iflyrc4fun
My Feedback: (132)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
www.desertaircraft.com
They carry Bolly, Mejzlik, Menz & Air Models props. However most of these manufactures cater to larger sizes.
Iflyrc4fun is offline
Old 06-04-2003, 02:28 PM
Spaceclam
Spaceclam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no. they don't makethem that small
Old 06-08-2003, 03:31 AM
slapshot
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
APC, they work great, and are readily available
slapshot is offline
Old 06-08-2003, 07:41 PM
Spaceclam
Spaceclam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i just got my apc 14x6. it worked jsut as well as the master airscrew, but not better. in that case, i will stick with the ma prop tdo i don't have to modify my spinner.
Old 06-09-2003, 01:15 AM
daw
daw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default prop
I've got four planes with 91 four strokes. Two TF warbirds one 10.5 lbs one 11.5 lbs both fly well with Graupner 14-7 props. A Citabria @ 9 lbs flys with a APC 14-6. A CAP232 @ 8 LBS. with an APC 15-4W. Very good vertical, the W is for wide, not the thin sharp typical APC it actually resembles the Graupners.
daw is offline
Old 07-03-2003, 08:37 PM
_kearney_
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
every prop has its advantage. wood is better for your engine and has less sound. I use the master airscrew props for my trainer
_kearney_ is offline
