Dalotel 74" WS need C/G
Hay guys, I am doing this for a friend of mine, we need the C/G for a dalotel 74" wing spand, dont know the manf. The wing leading edge taper on it, can you use 20% to figure the C/G thanks frank aka buffalowman.
Here is a simple method to find the CG . it takes a few minutes but it will get you very close the rest is fine tuning.
JUst follow the instructions on the link.
http://www.nsrca.org/technical/tip_tricks/mac_cg.htm
