Easy Sport 40 as a taildragger
My Feedback: (16)
RE: Easy Sport 40 as a taildragger
I don't have any pictures but it is easy to do
Put a 1/4" ply doubler in the radio compartment floor just behind F2 to attach an aluminum main gear. Use 1/4-20 nylon screws tapped directly into the playwood
For the tail use a plywood doubler glued on the bottom of the fuselage to attach your tailwheel mount. connect the tail wheel to the rudder abd that's it.
Here's an old Dig LT40 converted
The TW wire conn. to the rudder
Overall picture
Overall picture
My Feedback: (16)
I would use this tail wheel bracket with the Easy Sport
http://www3.towerhobbies.com/cgi-bin...&I=LXFV47&P=ML
I like this landing gear it gives you prop clearance for a four stroke
http://www.horizonhobby.com/Products...?ProdID=HAN160
