Materials used in real aircraft.
MA
What is the reason that the materials in modern fighter airframes appear yellow or green?
[link=http://gizmodo.com/5021998/build-your-own-f+35-lightning-ii-fighter-jet]f35[/link]
RE: Materials used in real aircraft.
having been in corrosion control for a short time and In the Marine Corps (usually near an ocean)..nothing corrodes faster than bare aluminum...wheel wells are usally painted white..but areas of the aircraft that don't see the light of day often are indeed painted with zinc chromate
MI
My father was a vetran of the U.S.Army Air Corps in WWII. He was a Field Service Engineer for Curtiss Wright. He told me that until the came up with zinc chromate primer it was very difficult to get paint to adhere to aluminum. Hence the puke green areas inside cockpits, wheel wells, engine bays etc.
Bill
Bill
My Feedback: (16)
I think the green stuff is also like Ram Jet Said has an ability to somewhat combine with the surface of the aluminum to promote adhesion.
I was going to say etchant but that is not the right word.
During WW II the Japanese apparently didn't have it completely figured out for the paint peeled from their planes all the time
The aluminum sheets used in the construction of aircraft is usually 2024-T3 Alclad of different thickness. Alclad is a composite material, consisting of aluminum combined with trace amounts of copper, manganese, magnesium, and chromium to give it strength and hardness. Coating the exterior of the sheet is a very thin layer of pure aluminum, which gives it corrosion resistance, since the pure alumimum soon becomes a layer of aluminum oxide that protects the alloy below.
Some preprocess the aluminum sheets with a alodine process, or slightly etch the surface. Other methods of surface prep may just skuff the surface lightly with Scotchbrite pads. Then a final cleaning and the application of the zinc chromate with the delightful Linda Blair pea spray green tint.
This was not done to WW11 airplanes sometimes for several reasons. It added weight, but more importantly, the expected lifetime of aircraft in war was measured in tens of hours.
there is zinc chromate green and there is zinc chromate yellow...green is the more often seen color...I haven't seen yellow in 25 some odd years
MA
How difficult is it to apply this zinc chromate primer? Can it be sprayed on with a standard air brush for scale applications or are the particles to big for such a device?
Testor's Model Master paint which is not fuel proof has Zinc chromate color....you can try fuel proof clear ove that..I don't know if it'll work or not
In full scale they stopped using "green" I think in the mid 1950's (military).
After that the chromate "yellow" became the new color of primer/corrosion coating.... including civilian A/C.
Forgot to add make sure you use an epoxy thinner.Normally you won't thin it more than 5 or 10%
In the aluminium boat building world i've had the opportunity to grind some etch off a recently sprayed boat.It completely penetrates the surface and will leave a stain behind that cannot be removed.
I was using it on military aircraft in the mid 70's and probably later...I know my military aircraft had green in them... my last squadron was 84
