hs-81 & somthin extra
Hey all, I'm trying to reduce weight on my somthin extra. I'm using a 225 on the throttle and wanted to replace it for an hs-81. Obviously their is no strain in this application but I'm wondering if it will handle the vibration from my saito 82? Has any one done this?
My Feedback: (85)
RE: hs-81 & somthin extra
A HS-81 will work allright. Myself i prefer the HS-85 in my opinion not that it matters much. Is better electronics and a stronger gear set. Of course it's probably eight dollars more. I have also use a Futaba S3101 and have been happy with both. The HS-81 when i've used it i have not been real happy with the pot life.
I've used 81's on the throttle of Q-500 racers. The trick to get them from dyeing due to the high vibration of 19 K is to have the throttle linkage split in half with maybe a quarter inch gap. You then join the linkage together with a small length of fuel tubing. If you get the right size tubing that is a force fit over a 2-56 pushrod end on both sides of the split it holds together real well but doesn't transmit the vibration to the servo. This is with Golden Rods. you know a tube in a tube pushrod.
