throttle servo
Old 02-19-2009, 01:26 PM
john911
Default throttle servo
i'm new to gas in my motor manual it sayes to put throttle servo 12"away.but on the plane the throttle mounting is 6"to9"away is this ok or do i need to move it
Old 02-19-2009, 01:48 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: throttle servo
It will be OK
Old 02-19-2009, 02:49 PM
TedMo
Really causing me to wonder why any manual would say that. Doesn't matter at all where servo is located far as I know. You say new to gas. Do you mean gas or glow? Some folks seem to group them together.
Old 02-19-2009, 02:50 PM
john911
gas
Old 02-19-2009, 02:54 PM
exeter_acres
exeter_acres's Avatar
assuming the linkage is set up correctly, you should be fine...
but is it the motor manual or the plane?
which motor..?
Most modern gas motors are shielded much better than they used to be...
Old 02-19-2009, 02:58 PM
john911
i't a spe 43cc that what it sayes12
it's a spe43cc it's sayes 12"away from the motor.i'm going to mount it in the spot provided on the plane.
Old 02-19-2009, 03:27 PM
JohnBuckner
JohnBuckner's Avatar
Spark ignition systems can and will induce RF interferance through any servo or servo wiring and that is the reason for the the suggestion. In addition this type of interferance can be induced through a conductive throttle pushrod. So using any spark ignition engine you should also use a non conductive pushrod such as plastic nyrod or equivilent.
John
Old 02-19-2009, 06:04 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Mount the servo as far away from the engine as possible and use the plastic Nyrod as John says
Old 02-26-2009, 04:54 PM
p39
Make sure you've got a resister plug.... use no metal to metal contact on the linkage... and if you're using a 2.4 gig system you'll be fine.
