seagull ultimate biplane 46 55
when i plull back hard elevator my plane rolls it has dual servos im using a splitter to make them work with my futaba 6
RE: seagull ultimate biplane 46 55
This reminds me of the old joke:
Patient: Doctor, it hurts when I do this.
Doctor: Then don't do that.
When you pull back hard on the elevator, you are causing one wing to stall before the other resulting in a snap roll. This is good if you're trying to do a snap roll, but not if you're just trying to go vertical. If that's the case, pull up gently, banging the sticks around will just result in undesired results.
Bottom line: Don't try to do things that the plane is not designed to do.
