Monokote fix
Monokote fix
Ok, how do I handle this. This was looking great when it was done last Novemeber or so. Been in my workshop since it was finished, hasn't even been maidened yet. Any idea how I can get rid of the bubbles and wrinkles? The checker graphics were custom cut for me, they DO NOT like heat. Kinda want to melt if you know what I mean. I'd like to smooth things out again before I take it to the field but am at a loss as to how. Suggestions? Before and after shots.
Dan
Dan
RE: Monokote fix
Sock covered iron and shrink it back. If it is a sticker or sticky trim sheet, small pin hole in one side and a credit card as a squeegee and press it towards the pin hole.
Dru.
Dru.
PA
RE: Monokote fix
Yeah,thats gonna be tough if those graphics arent made from monokote or ultracote or something like that. They could be vinyl though if they were custom made. If you can heat it,dont be afraid to put some tiny holes in it like buzzard said. If those black graphics wont take any heat,maybe you could carefully peel them up,shrink the white,then stick em back down(doubtful). Maybe worse case scenerio,you could cut the whole length of the elevators trailing edge,lift the covering on the whole elevator and try to stretch in tight and re-iron the whole section down(yeah,sounds crazy,lol). I just hate to see you make it worse trying to make it better. They really are cool looking!
Well,I guess you could also just cut the black section instead of the whole elevator....lift it up and re-iron just that black section back on maybe. And then play around with the white parts(they dont look to hard to fix).
PA
RE: Monokote fix
And I think its gonna take alot more than just some ironing to shrink that out too. That would take some major heat from a heat gun to get those wrinkles out,and if he's saying that black doesnt like heat......well,we'll need an option B.
My Feedback: (27)
OH
RE: Monokote fix
Doug
RE: Monokote fix
Thanks to everyone for the help. Took about 1/2 hour to do one elevator but she sure looks alot better. Sock covered iron, medium heat and some pinholes in the film. The iron wanted to drag across the graphic with the slightest movement so I found that if I held the iron still for a few seconds and built the heat up slowly, they shrank themselves out.
Thanks again,
Dan
Thanks again,
Dan
RE: Monokote fix
As you can see, you are the first to have that happen. .
The pin hole is an old trick. The heated air has to go some place. teh hole is small enought to not worry about. If you do worry, a tiny drop of Ca will seal it up.
Looks a lot better all smoothed out. Good job.
Dru.
Dru.
RE: Monokote fix
Thanks for the compliments. I'm going to tackle the other elevator tonight and make my way around to other areas that I noticed have puckered.
While everyone is so helpful I'd like your opinions on another aspect of covering. On sheeted surfaces I generally try to use the lowest heat setting on the iron that will adhere the Monokote without causing bubbles to appear. Seems to work very well but I'm wondering if that didn't contribute some to the bubbles forming down the road. I have other planes Monokoted years ago with the same technique and they still look great. I guess what I'm asking is how much heat on the iron do all of you use for sheeted surfaces? I have noticed that if I do have to remove Monokote during the process of applying it, for whatever reason, it seems to come off much easier than it should. At least to me it seems to. I finish the balsa with 600 paper, vacuum and tack before I start so I'm confident it's not a dust issue. Hope what I'm trying to say makes sense. Suggestions?
Dan
Dan
My Feedback: (27)
OH
RE: Monokote fix
I sand with 320 and vacuum the airframe. Then I give it a coat of Coverite Balsarite. Then I give them a quick once-over with 400 before covering. The Balsarite makes films stick like glue. It eliminates the problem you're having now too. My hobby shop was out of it when i covered my last project. Now that it has sat for several months, there are sags and bubbles in the Monokote... I knew I should have waited until I had more Balasarite. But, impatience got the better of me.[]
RE: Monokote fix
Yes Balsarite is the answer to most any covering issue. I use it for every covering job. Too bad I can not get it anymore in the Republic of Kalifornia. It contains bad stuff so they will not sell it here. The best I can do know is Sig Stick it and thin with acetone. I have a coupel 20 year old covering jobs that look good. That is after hanging in the garage through 110 degree summers and 0 degree winters.
Dru.
Dru.
RE: Monokote fix
Split S, Good job on working the wrinkles out of the covering..
Ihave a couple of questions - the monokote covered fuselage (solid sheeted) wrinkled from the sun. (But, the wing looks great still)...
I did use Balsarite on the whole plane before I started covering, but still got the sags and wrinkles on the sheeted fuselage..
My quesitons are:
1) when you say "sock covered iron"are you using one of the light material Monokote Socks (which I use all the time) or do you use a thicker sock from the drawer?? Like your own...
2) when you "roll"the iron across the wrinkle is it like you are starting at the "heel"and then tilting the iron down to the tip, like taking a step with your foot?
3) How are you working out the wrinkles with "No Pressure"? Not actually pressing the covering down, just letting the iron set on the covering.
Lastly, any luck with a heat gun and then gently rubbing the monokote back down?
Any thoughts on this will be great. I already put the vinyl graphics on the Skyraider and really don't want to screw it all up..
Thanks...
My quesitons are:
Thanks...
