removing paint from plastic parts?????/
IL
You can try one of those orange based paint strippers. They work on some plastics, it depends on the type. As always though, try it on a scrap piece first.
My Feedback: (7)
TX
Highflier353535,
I have used "EASY OFF OVEN CLEANER" on plastic models (previously built by someone else) to re kit and remove the paint.
Now if I could only remember what to use to remove chrome from plastic. Does anyone remember?
R. C.
R. C.
Banned
safest paint remover for plastics is brake fluid.just soak the part wet either in a bowl or wrapped in paper towels wrapped in plastic for a few days brush off loose paint with tooth brush.water soluable so just clean up with soap and water.
