Satio 150s rpm?
ON, CANADA
Satio 150s rpm?
Im finishing a 60 size Carl Goldberg Extra 300s with a Satio 150s, I was wondering if anyone running the 150s could tell me what type of rpm it will turn with 18X6 apc?
CO
RE: Satio 150s rpm?
I think that will depend on your fuel, altitude, prop material, etc. If it does not get into the acceptable rpm range for the motor you should switch. Otherwise you just tune at 200 rpm less than max. I found mine will miss a little if its not rich enough and it gets just a little leaner at flying altitude so if you hear it missing you should richen slightly.
