Added Safety
Added Safety
I was on HobbyKing.com looking around and I noticed that they have a 15A regulator, the kind that I'd get to run a 2S lipo on my receiver, with a fail-on switch. I really liked that idea. A switch that didn't close a circuit, but one that would open a circuit....if that makes any sense. Like, most switches are made to open a circuit by default and close the circuit when it's switched. From what I understand, this one works the opposite way. I've seen many switches fail before, and heard of even more failures.
I guess what I'm asking is where can I get these safety switches, and are they really worth it? I'd hate to crash my favorite plane because my SWITCH failed!!
RE: Added Safety
Holy crap!! That's an expensive switch!! All I know is that that thing had better work miracles for $25. It does look nice, but my biggest engine is a Saito100...so I don't think I really need that nice of a switch quite yet. Is it fail-on, though?
My Feedback: (8)
RE: Added Safety
Considering that switch has a built-in battery meter ($12) and charge jack ($3) I'd say it's not terribly expensive, and is much cleaner than installing component wise.
I am interested in this 'fail-on' switch as well, so anyone with any experience please chime in
RE: Added Safety
I've seen this one used at our field. Very bottom of the page. Pin and flag fail safe. Its used on a 150cc Python biplane.
Edwin
http://www.chiefaircraft.com/rcmsec/...Smart-Fly.html
Edwin
RE: Added Safety
Just guessing, but probably yes. The guy that uses this one in the club also runs the regulators. When you have that much invested in a 150cc plane the cost of a switch like this is nothing. On the other hand, for a typical medium sized arf, would be hard to justify. I check my switches once and awhile using a transformer type of ordital sander. Leave the paper off and just hold it up against the fuse new the switch. I use a led voltage monitor to see if the voltage jumps around. If it does, in goes a new switch.
Edwin
Edwin
