Just simple question!?
Hello everyone
I am planing to buy USB cable to connect my Futaba T6EX 2.4 to use it with FMS , my question is there is anyway to disable radio signals to save battery drain during playing with simulator?
Thank you for your help
Mo
Mo
NY
RE: Just simple question!?
You may not have to turn the radio on. The adaptor I use with my JR radio and Phoenix sim uses the power from the USB port to power the radio.
Thank you for replying
that is cool I hope with mine would be the same, but please tell me is all the switches working as well or just the sticks?
My Feedback: (8)
I used Futaba radio with FMS, had to turn the radio on. I only remember getting the sticks to work. The radio gets calibrated under the Joystick feature of the software. There is no way to disable features that I am aware of, but regardless it is a good idea to setup a separate channel just for computer use.
Banned
ORIGINAL: huck1199
Same here, with my JR it uses the power from the USB. I guess JR had that in mind when they developed there radios. [8D]
MI
I have the Futaba 7C 2.4GHz and use a USB cable. The radio has to be on in order to use the simulator. Depending on the software you run the switches may function.
thank you so much all for helping, I am thinking to get a realflight or something else witch will come with joystick to avoid using the radio all the time because my radio battery take ages to charge
CA
PcMac,
Pull the crystal out of the transmitter.
This also prevents a problem if someone is flying in the area.
Where are you getting the cable from?
Good Luck,
KW_Counter
Good Luck,
KW_Counter
