Best Airline Connectors ?
My Feedback: (24)
Wondering which airline connectors are best and less prone to leaks ... the Robart quick-connect type .... or the type that screw together (2 knurled brass ends with an 0-ring) ? On the larger scale aircraft ... I seem to notice more of the screw together brass type. Bob
1 Post
RE: Best Airline Connectors ?
Hi Bob,
I have used the Robart connectors without any problems to date. Even if you get a leak, assuming air up and spring down, the worst thing that can happen is the undercarriage will extend early.
Cheers,
Colin
Cheers,
Colin
