What kind of plane is this?
Hard to say, can you post a bigger pic?
BTW, there's a minnesota fly-in on June 28th in Willmar. See this thread:
http://www.rcuniverse.com/showthread...31&forumid=225]
Nope
I would have to say it is a Balsa USA thunderbug 120. All of the other planes being talked about come with aluminum gear...the B-usa kits come stock with wire gear...most guys however modify the wire into aluminum type attaching to a plywood plate installed during construction and attach wheel pants.
So there you have it.
