9CAP THrottle trim and cutoff
I have been trying to set up a Nextar with the Futaba 9c and Hitec Supreme II receiver. All functions seem to work well except I am unable to get the throtle trim or the throtle cut function to work. I have reset all parameters and am able to use end point adjustments to set all control throws. The trim levers work on all other channels except throtle.
I tried different servos on the throtle channel with the same results.
I am starting to think that it is a problem between the Futaba tx and Hitec rx. Perhaps they are not entirely compatable with each other.
RE: 9CAP THrottle trim and cutoff
I finally figured it out. I had to reverse the throttle trim so it worked in the lower half of the position. Problem solved!!!!
