Lengthening Brass Rods
Ok, I know this might not sound RC related but it is. It's been years since I've welded anything but I still have all the equipment (gas and electric). Can anyone remind me if it's possible to weld brass rods together ? I seem to recall they can be gas welded but not electric welded because of the copper - does this sound right ?
GA
You're better off soldering brass rather than welding. I've never tried to weld brass but would imagine that if you're talking about large rods, welding might be the way to go. Most brass used in the RC hobby requires soldering due to its small size.
Banned
The high temperature joining of brass is called brazing; where you apply flux to the joing and add brazing rod, heat until the rod melts and flows.
Les
Les
Thanks Les, Yes this is coming back to me now, I still even have brazing rods. But, do you know if I can arc weld them together ? Brazing is strong but the extreme heating of it also discolors the brass, a small arc is nice and neat.
If you are trying to butt weld thin brass rods - you will struggle with brazing because of the temperatures needed. I would suggest that if possible you use a brass sleeve over the join with a good fit and silver solder the joint. Silver solder is not the stuff you get on a roll from the electronics store...it is a metal rod like a brazing rod with a high silver content which, will melt long before the melting point of your brass rod but it makes a good strong joint.
I doubt that you could arc weld them unless you are really handy with this technique and can get the correct electrodes (this applies especially to thin materials).
