Help! I messed up
MO
Help! I messed up
Hey guys - I bought the aero works extra 260 60-90. Great looking plane, I think I'm going to love it.
BUT I messed up on the stab installation. You can see in the picture here
http://www.aero-works.net/store/imag...60_large17.jpg
that the stab AND elevator go in a slot together. Do do this, you are supposed to put the elvator in first, and push it back to make room for the stab. Then epoxy and insert the stab.
I put the stab in first. I got it out in time to wipe off, but on the wood, it did not wipe off of course. It soaks in quickly. Should I try to sand the stab, and the inside of the fuselage a little before reapplying and installing?
ALSO - I think I may go with 2 mini servos in the back (they have a slot precut for it). If I do this, should I cut the elevator in half ANYWAY (which means it wouldn't have mattered that I put the stab in first so that they have independent trimming?
Thanks!
Tim
Thanks!
Tim
RE: Help! I messed up
I have rebuilt airplanes before where the tail was the only thing to survive a crash. I would order a new fuselage and just get the old tail feathers out, sand them with a dremel back down to the wood (through the epoxy) and then just do it like normal. I think your situation will be similar, especially since you noticed your mistake and got it out quickly. Sand it down and you should be good. I am not sure what to do with the to micro servos and seperate elevators. Good luck
MO
Ok, so that leaves me with only the one question then
If I go with Dual elevator halves, should I cut the elevator in half? Is there a big advantage to having 2 halves or will it be fine with one?
TIm
TIm
