Expert glow driver
FL
Expert glow driver
I have the expert onboard glow driver. I need to know if the leads to the glow driver need to be reversed? I can't seem to light the glow plug for starting
RE: Expert glow driver
Did you program it to come on with throttle? Did you leave it on for a long time and burn out the glow plug?....Lastly this is a real stupid question did you remember to hook the black wire to the engine and when trying the glow plug to touch the outside of the plug to the engine?....I have used this on board glow a few times....I fly at both J-ville clubs...If you want, send me a private mesage and we can discuss this on the phone.
FL
yes it is programmed with the throttle, did not leave it on too long, yes it is grounded good. I use an f plug on a 0s 160 and tried a few different batteries, found out my wires were too small and too long so trimmed them down and then pooooffffff, hooked up a 4 cell battery after trying with 1 cells and not getting enough glow and the 4 cell burned out the plug, I am at my wits end with this thing.
FL
Well folks, here is the cure to this Expert onboard glow driver. Make sure that all your wires are as short as possible. I did use a switch for my battery but had to cut the wire on the battery to make them shorter. Doesn't really matter what gauge, just make them short as possible. Now for the real culprit, It really doesn't matter what polarity is coming out, whether you reverse the out going or not. just make sure that the battery is done as per instructions and labels. I did reverse the output polarity but it didn't make any difference. Just make sure your wires are as short as possible and it should work as it should, with 4cell or 5cell or even a 1 cell. It is work good. Another thing is make sure your switch is rated for 5 amps or more. This things draws about 3-4 amps when it is on.
Again, THE SHORTER THE WIRES, THE HOTTER THE PLUG WILL GET.
My Feedback: (22)
FL
am I wasting my time with this unit as I got one from an estate and was going to finally use it but after reading this I might just go to electrodynam as they hav a unit also.
My Feedback: (10)
MD
I just bought a Gee Bee with the Expert glow driver on it. Flew it two times and it burned out. Bought another one and installed it. It lasted six flights and burned out. Called the company and checked to see if I was doing anything wrong. Everything was hooked up as per their spec. They sent me another unit. Since then I installed Saito Radial and also installed the Electro Dynamic multi cyl unit and have flown the plane about ten times and the unit seems to be working perfectly. My choice, even though it's much more expensive, is the Electro Dynamic unit.
ORIGINAL: Carlos Murphy
I make my own OBG drivers using a rechargeable C cell, glow plug connector and a toggle switch.
I leave it on for the whole flight, flew 4 flights one day powering my Super Tiger 90 and had plenty of juice left, it has never gone dead on me.
I just found the post I made this past summer with a simple diagram. For one glow plug, just remove the second glow plug wire and use only one battery. http://www.rcuniverse.com/forum/m_88...tm.htm#8898804
