OS-70 4 Stroke needs airplane
NY
Bought an OS70 to use in Seawind and switched it out for a 91. Now I need a plane for the 70 4 stroke. I want a stick but the 40 is too small andd the 60 stick is too big. Your recommendations are appreciated.
My Feedback: (8)
RE: OS-70 4 Stroke needs airplane
I'm really enjoying my Venus 40 right now. It would do well with a .70 four stroke:
http://www3.towerhobbies.com/cgi-bin...&I=LXBMZ5&P=ML
U can do 46 It should be perfect for a 70 4stroke. A guy at the field has one with a ys 63 and it hovers with power to spare so I think a 70 will be good. Also, the great planes cherokee is nice.
ORIGINAL: lazaras
...Now I need a plane for the 70 4 stroke. I want a stick but the 40 is too small ...
My Feedback: (-1)
ORIGINAL: MinnFlyer
If you don't mind building, the Goldberg Clipped wing cub is ideal for an OS70
Another good choice would be a 40-size warbird
Ihave never installed one in any of the warbirds myself but I have seen a number of them using the .70 for power and they looked and sounded impressive.
The .70 was one of the great engines from OS and worked well in any 40 size plane and a lot of 60 size planes too.
When Iwas having problems with the CG on a Smith Mini Plane Iinstalled the .70 and that cured my problems and flew it a bunch better then the OS .46 FX two stroke I had in it.
Now the big question, what does a scale stick look like on a fly by???
AZ
TANGO - They fly great on the 70. On high rates you can hold altitude in a flat spin. Unlimited vertical. The airplane is too draggy to go very fast but it will do amazing things with all that power..
My Feedback: (264)
MD
ORIGINAL: lazaras
The 60 size US is a very light weight plane for its size.
I really like mine on my 4*60. Kept it light, 7 lbs even. Lovely with a 14x4 prop...not fast, but very aerobatic. Depends on the kind of flying you like. The GP CAP 40 kit is another idea if you want a smaller, high powered type. The designer flew his with the OS .70 in competition and thought it was perfect. Jim
