Senior Kadet
Senior Kadet
I have just received my new Sig Senior Kadet. I will be using a 4-stroke .70 engine. Any opinions or experience with engine mounted upright or inverted. I was thinking inverted to hide in the cowl. Also maintain a better center of balance or rotation. Please advise.
RE: Senior Kadet
Congratulation you have just choosen one of the best and most successful trainers in the history of RC. Suggest you mount the engine as intended. Inverting will not give you a better anything aerodynamically. There are a host of potential problems you can run into inverting and one of the biggest is dificulties in using an ignitor conviently on the plug and a remote connector presents even more convience problems such as what happens when you want to change, check or clear a plug.
Its the best trainer ever let it do its job and don't get caught up in the common obsession with cowlings that have no holes. The engine must be allowed to do its job it must be allowed to breath and High speed needle valves, low speed needle valves as well as the glow plug needs to be completly accessable from the outside.
John
John
CO
RE: Senior Kadet
I have to agree with John. You've got a great combo there. Four strokes can be successfully set up to run inverted....I have several. But in a plane like a Kadet it's much easier to set up in the upright position and inverting it won't improve the aerodynamics. Upright is simple, runs cool, easy to apply the glow plug and will idle very well.
Save the challenges of inverted, closed cowl intallation for your first Mustang or P-40.
Enjoy the Kadet!
Enjoy the Kadet!
RE: Senior Kadet
Thanks for the great advice. I flew a Senior several time when training. I loved it then and I look forward to flying my own. I will mount upright and enjoy.
Thanks.
Thanks.
RE: Senior Kadet
You have an incredible combination! I've had two with .91 4-strokes. It'll love the 70 and fly around nice and slow at 1/4 throttle. Great combo, congrats on your new best flying plane. Here's my last one with the 91.
