Spektrum DX7 Travel Adjust-Hi and Lo rate
ON, CANADA
Sorry for the lame question but here goes. Building my first ARF (Pulse XT60). I have adjusted the low rates on the elevators to manual specs. Then adjusted the high rate to manual specs. When I switch back to low
rate the travel has changed by the amount of change I applied to the high rate. Isn't it possible to set different low and high rates?
Thanks in advance!
Thanks in advance!
RE: Spektrum DX7 Travel Adjust-Hi and Lo rate
Yep, piece of cake. Where are you setting high and low rates at in the menu?
Go the the section that shows expo and dual rates.
To set the high rates, put the switch in high rate position and set the throw percentage. I usually try to keep this at 100%. For low rates, flip the switch and lower the percentage. I'm at work but I can take pics of the menu when I get home.
