Ideal Wing Loading for acrobatic planes?
My Feedback: (131)
I typically fly warbirds which have pretty high wing loadings, but I now have my 1st acroplane.
I have a .45 size EDGE 54O, and it seems rather heavy considering what it is.
...I know that some of the bigger planes actually seem much lighter, given their overall size (engine is by far the heaviest element), but is there some ideal ratio of Wing Area to weight (wing loading) for acrobats/ planes?
Thanks in advance.
Thanks in advance.
My Feedback: (-1)
RE: Ideal Wing Loading for acrobatic planes?
ORIGINAL: MinnFlyer
Not really.
If you're flying 3D, you want as light as possible, but some of MY favorite acrobatic planes have had a very high wing loading (as much or more than a warbird)
Not really.
The truth is, wing loading does matter for 3D, precision, and landing. The smaller the airframe, the more it is effected. If you are wanting a really good loading in all areas for an airframe that small then I would shoot for a 25-30 oz. loading. JMO
Bob
Bob
Wing loading can lead to deceiving results, WVL (wing volume loading) is a much more realistic way of determining flight characteristics. A value of 7 or less is usually a real floater but most planes fly well with up to a WVL of 11, some even with a slightly higher value. WVL is sometimes refered to as Wing Cubic Loading if you are interested in searching for comments and formulas.
Yes, very true however as an airframe gets smaller, the Reynolds numbers drop with it along with Efficiency to carry weight.
Bob
Bob
ORIGINAL: sensei
Bob
Bob
Here you go, just click this link and you can find out what your wing loading, and cubed loading is, if you strive to stay within these guidlines, you will do just fine.
Have fun, Bob
http://www.ef-uk.net/data/wcl.htm
Have fun, Bob
