Reload this Page >
2.4 transmitter
2.4 transmitter
Old 07-20-2009, 05:07 PM
Hircflyer
Hircflyer's Avatar
Default 2.4 transmitter
Can you use a buddy box and trainer cord with a 2.4 transmitter?
I have a new Futaba Transmitter and an older Futaba buddy box with a round plug and cord, will this set up work?
Thanks in advance.
Old 07-20-2009, 05:22 PM
The Ghost
The Ghost's Avatar
Default RE: 2.4 transmitter
Don't know about Futaba (never owned one), It works with JR and Spektrum. 2.4 transmitters are the same as earley transmitters in the encoding only the output side is different.
Cheers
Old 07-20-2009, 07:32 PM
draftman1
draftman1's Avatar
yeap, it will work, i have done it, you need to get that cable.
Old 07-22-2009, 12:05 PM
richardgerardi
Yes it will work fine just have to activate the trainer option to make it active on both radios. Good luck
Old 07-22-2009, 12:29 PM
JohnBuckner
JohnBuckner's Avatar
If whatever your older Futaba is has a round plug and the newer futaba has a square plug then be carefull when ordering that you order the round to square plug.
John
