incidence meter
RE: incidence meter
thrust line from the front of the motor all the way down the fuse to see if your motor is pointing up down left or right. Which I thought thats what they did when they drilled the hole in the firewall of an ARF kit but I was wrong found that out in another topic how to mount a motor!! some just drill a hole to run the fuel lines through!!!
My daughters little ipod touch level is an awesome tool checking degrees to the nearest tenth I use it for control surface throws 90degree angles for my stabilizers. And pitch gauge for my heli but thats a different forum.
