Landings without landing gear, advice on
Reply
Old 06-25-2003, 07:18 PM
Richardfast
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Landings without landing gear, advice on
I have a small Spitfire with an OS Max .30 FS engine. I hand launch the plane due to high grass and small wheels, but I land OK on the supplied gear and wheels. I would like to fligh this plane without gear and just belly it in like the electric boys. Any experience with this? Is the prop always going to move out of the way or am I in for a broken prop and maybe firewall?
Richardfast is offline
Old 06-25-2003, 07:53 PM
big max 1935
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the prop is positioned correctly in relation as to where the compression stroke starts it will stop probably within a 1/2" most times. I don't think I would use a wooden prop though! The firewall should be OK if you are smooth. MAX H.
big max 1935 is offline
Old 06-25-2003, 08:20 PM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup, set the prop so it meets the compression at the 3 O'Clock position. Kill the engine and the wind should spin the prop until it meets the resistance of the engine's compression.
MinnFlyer is offline
Old 06-26-2003, 02:23 AM
Dsegal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As pointed out above, you are unlikely to break a plastic prop on landing. The real secret though is that landing without wheels is so much smoother than landing with wheels. You just grease the model onto the grass and everyone thinks you are an expert!
Dave Segal
Dsegal is offline
Old 06-26-2003, 03:59 AM
big max 1935
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just don't do a three point landing , nose , wing tip & tail! Hard on things . MAX H.
Old 06-26-2003, 09:00 AM
Richardfast
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for all the help, guys. The landing gear is coming off soon. A wheels up Spitfire is a pretty sight.
Old 06-26-2003, 01:29 PM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can say THAT again!
Take a look at the videos of the one I just reviewed in the RCU Magazine.
Old 06-26-2003, 02:07 PM
BillHarris
BillHarris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sailplanes are gearless and frequently nylon landing skids are used to keep the belly from getting bunged up. Some skids are small an inconspicuous.
http://www.superskeg.com/
FWIW.
--Bill
BillHarris is offline
Old 06-26-2003, 03:44 PM
FLYBOY
FLYBOY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a few that don't have gear. As stated, land light and you won't have a problem. I use APC and Master Airscrew props and they don't break often. I don't like landing on dirt or asphalt. Makes a mess in the carb. Make sure you don't have dirt in it after landing if you are going to run it again.
FLYBOY is offline
