Ok to Modify a prop??
Old 08-02-2009, 08:22 PM
Trax540
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ok to Modify a prop??
Was curious if its ok to sand off the factory clear on a prop and restain it to suit my build as long as i reclear it and balance it??
Building a Pup and i cant find a vintage looking prop for it so i wanted to get as close as i can
Thanks!
Trax540 is offline
Old 08-02-2009, 08:36 PM
Dorsal
My Feedback: (17)
Dorsal's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Ok to Modify a prop??
That'll work just fine. Try not to change the shape of the airfoil.
Dorsal is offline
Old 08-02-2009, 08:43 PM
Trax540
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yea i took that into consideration, just wanted to double check as i have never attempted it.
Thanks much!
Trax540 is offline
Old 08-02-2009, 08:51 PM
tryan02
tryan02's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I havent tried it on a plane prop but a denatured alcohol or mineral spirits would remove the clearcoat rather than sanding and changing the balance or deforming the airfoil.
tryan02 is offline
Old 08-03-2009, 06:23 AM
airbusdrvr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Would sanding with something like 400 grit not roughen the surface enough that your color coat would adhere?
airbusdrvr is offline
Old 08-03-2009, 07:31 AM
j.duncker
j.duncker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sanding is fine, propably better than paint stripper or thinners which might warp the prop. We used to do this all the time with pylon race props to get better shapes.
Wick some thin CA into the end grain on the tips for some extra strength.
Just balance it before you paint [ sanding ] and then again after [ use an extra coat on the light blade ]
Why not do two! These sucker nose over.
j.duncker is offline
Old 08-03-2009, 07:56 AM
Trax540
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: airbusdrvr
Not using a color coat persay as in painting it. I am going to Use a wood stain so i need to get the clear off so the natural wood accepts the stain
This is the effect im going for except i want just abit darker and i will probably have to paint on the effect of the metallic strips and rivits rather than actually attach them as i do not know how that would effect it in flight
Trax540 is offline
Old 08-03-2009, 05:37 PM
tryan02
tryan02's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
paint thinner warping well maybe but I dont think so used it many times on finishing furniture with 1/16" luan. But thats why I suggested mineral spirits or denatured alcohol not as strong and with alcohol bases they will dry almost instantly not letting it absorb into the wood and warping it. We all know the clear on these props is pretty thin it wears off after a year or two of flying so it doesnt take sandpaper to remove it. The thing about sanding is you cant do it evenly the heat from friction melts the clearcoat and gums up the sandpaper and you will find yourself quickly unevenly sanding making high and low spots on the prop.
oops once again I havent done this to a prop but have refinished furniture many times some even made it to movie sets.
hope you get er done that will be an awesome look.
tryan02 is offline
Old 08-04-2009, 07:33 AM
Trax540
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ive have a ton of old props that i dont forsee using anytime soon, so i will give the alch or spirits a try first to see how it takes. Worse comes to worse i will get out the belt sander and just rip that clear right off really just kidding about that, Il use the bench grinder
Thanks everyone for your input i appreciate it.
Trax540 is offline
Old 08-04-2009, 08:39 AM
Jonathan Ott
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[link=http://www.xoarintl.com/props/ma/PJWWI-Scimitar-light.html]Xoar Propellers WWI Scimitar[/link]
They also have a "Lance" blade, and a "Saber" blade.
Jon
Jonathan Ott is offline
Old 08-04-2009, 09:56 AM
Trax540
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did see Xoar props however i dont think they make the size i need.
The smallest size i found on there website was 18x...
Im going to be running a 91 Saito and 18 is abit to big [&o]
That scimitar they sell is pretty much the look im going for though
Trax540 is offline
Old 08-04-2009, 03:42 PM
Stew99
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a thread on simulating the look of vintage laminated props:
[link=http://www.rcuniverse.com/forum/m_4575578/anchors_4598695/mpage_1/key_/anchor/tm.htm#4598695]how to fake a scale wooden flying prop[/link]
Stew99 is offline
Old 08-04-2009, 04:19 PM
Augie11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Master Airscrew sells wood scimitar props in the size you need. I just bought a couple for a Saito 1.25 in a BUSA D-VIII. Tower carries them.
Augie11 is offline
Old 08-05-2009, 02:51 PM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
You can modify (carve , Cut, file and sand) any prop as long as you know what you are doing!
jaka is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
