Prop selection?
IL
Prop selection?
Going to be running a 91 Saito and the rec range for props goes up to 14x8
Its going to be on a Pup and a few people have told me i should go high dia low pitch
My question is
Can you exceed the rec. range by lowering the pitch.
Would the 91 run say a 15 or even a 16 by lowering down to maybe a 5 or 6 pitch?
Or would it be inefficient to run it in such a way.
My question is
IL
RE: Prop selection?
Anyway to stick to a wooden prop?? Would that make a huge difference, this is going on a Sop. Pup i was planning on altering the visual scheme of the prop to more match what they originally looked like.
RE: Prop selection?
Xoar makes a 16x4 wooden prop. This is one good source for them http://franktiano.com/xoarprops/xoarprops.htm or you could do a Google search to find others.
