prop balancing
Reply
Old 06-29-2003, 04:07 PM
robalex32
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default prop balancing
i'm balancing a 3w 26 x 8 prop on a du-bro balancer
always stop on one side 9-3
this means that the hub is heavier on that down side?
thanks.Alex
robalex32 is offline
Old 06-29-2003, 04:32 PM
KJohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am assuming this is a two bladed prop.
Are you saying that when the prop stops the SAME tip is ALWAYS on the 'left'?
If so then the hole may be OFF CENTER or the hub is larger and/or heavier on that point that is now at the bottom.
I assume the balance unit does NOT have a rough spot right where it stopped.
KJohn is offline
Old 06-29-2003, 04:43 PM
T_Hill
T_Hill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, it means that that half of the prop is heavier, not just the hub. You can balance it in several ways. You can spray clear on the respective leading edge of one blade and the trailing edge of the other or remove material from the heavy sides. You can also put screws into the light side of the hub. When properly balanced it should stay in any position you put it in.
Tracy Hill
T_Hill is offline
Old 06-29-2003, 05:20 PM
robalex32
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the promp reply,now I can finish this,but what is the best to do ,remove material for one side or ad weight with screws on the other?
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it's even tip to tip, but top/bottom heavy, that means that it's not out by much. You can make it better if you want to, but I wouldn't get too anal about it.
MinnFlyer is offline
Old 06-29-2003, 09:25 PM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know people do it but I would never remove material from a propeller. Always add some paint for weight.
Geistware is offline
Old 06-29-2003, 11:13 PM
T_Hill
T_Hill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use to remove material, the problem is you then have unsealed wood and the balance changes. Now I use clear on the blade, hub. I've had some that were really bad and used screws on them. Most of the time paint works fine.
Tracy Hill
T_Hill is offline
