:confused:
:confused:
I have a DAZZLER that I can't get to do a very good snap-roll I have moved cg back but still can't get a good one. I don't know if the ailerons are to far down causing the wing not to stall, or the just the thick wing just wants the fly to good. Only thing is it does negative snaps pretty good. It seems like the ailerons need to be raised but don't know how it will fly.
:confused:
Hi FLYBOY,
Are there true snap rolls and fake ones? Why is a "true" snap with only rudder/elevator?
The couple of descriptions I've read on how to perform them indicate burying the sticks in the corners (which necessarily includes aileron).
Here's one.
Thanks!
flianbrian
Here's one.
Thanks!
flianbrian
:confused:
I have the rudder touching the elevator, I did that trying to get more gyro but it still does a slow ragged looking snap, not as crisp as I would like, I was thinking my ailerons were acting as flaps and not letting the wing stall properly since it seems to do better at negative snaps, it really winds up good inverted. I may have to cut my elevator to get more travel. I also have the elevator going past factory specs.
Thank you for the advice.
:confused:
Originally posted by flianbrian
Hi FLYBOY,
Here's one.
Hi FLYBOY,
Here's one.
HTH
Tom
