Reload this Page >
making checkerboard patterns
Old 09-28-2009, 01:07 PM
spitfire66
spitfire66's Avatar
Default making checkerboard patterns
Hello, I was curious how some of you make your checkerboard patterns for the rudder and underside of the airplane. I am wanting to do a purple and silver checker. All that I have found is white and clear checker pattern. I am wanting to make the pattern small since it is going on the rudder of a 40 size plane. I know that I could try to cut them out, but that will be hard to get them symetrical and perfectly spaced. Does anybody have suggestions?
Old 09-28-2009, 01:32 PM
mclina
mclina's Avatar
Default RE: making checkerboard patterns
Ultracote does have decent variety, but no silver and purple.
http://search.horizonhobby.com/index...000&N=5729+632
Small squares are tough to do by hand.
Old 09-29-2009, 07:47 PM
spitfire66
spitfire66's Avatar
Thank you for your reply. I think I am going to call a graphics company and see if they can help me out. Thanks.
Old 09-29-2009, 09:51 PM
daveopam
My Feedback: (9)
daveopam's Avatar
If you use Monocote brand and use the Windex method, you might get some good results. Might be a little tedious work thought.
David
Old 09-30-2009, 12:31 PM
huck1199
huck1199's Avatar
Look at what Hobbycity has for colors. I bought their red/white and was happy with it.
Old 10-04-2009, 09:48 PM
Squire
Squire's Avatar
IF you are willing to paint instead of stick-on then it really isn't too difficult. You can purchase masking tape of various widths at an auto paint supply store. First, paint the whole area one of the colors you chose. The idea here is to lightly mark using a soft pencil where you want the checker pattern to be. Then cover the entire area with tape that will be the width of your checks. Now with a ruler and again that pencil draw lines perpendicular to the tape and on the tape. The edges of the tape and your lines will form squares. With a VERY sharp #11 blade carefully cut the tape along your pencil lines. When finished, remove the alternate squares and spray away the second color. Viola! Checkerboard pattern.
Hope this helps.
Phil
Old 10-04-2009, 10:32 PM
anuthabubba
My Feedback: (102)
Cover the background of the area with silver or the lighter color of your intended pattern and measure/cut some long 'ribbons' of the other color. Cut the ribbons into squares and measure/place them on the background color. Rub them on to get the air out. It's easier than painting. I do it without using the Windex method. The squares usually stick in place until I iron them down.
Terry in LP
Old 10-05-2009, 11:16 AM
Deadeye
Deadeye's Avatar
Just use Monokote and Windex and do it by hand. Straight checks are easy compared to curvy ones.
ID:	1288684   Click image for larger version
ID:	1288685   Click image for larger version
Old 10-05-2009, 07:08 PM
Augie11
I like anutha's method and I've used it a dozen times. Works with film or fabric. Patience pays off!
Old 10-05-2009, 08:34 PM
bgfireman
My Feedback: (13)
bgfireman's Avatar
Use the windex method. It works great. A plane going by at 50 plus MPH. Who can tell if they are the same?
Alan
