Help with a new plane doing loops.
Hello,
I have a zen 30 with a .46 fx installed.
The plane flys great but when I do a loop the plane will go straight up and will not complete the loop. It will bail out.
Almost like it don't have enough power to flip the plane over a complete the loop???Any suggections
I believe everything is good the wing is on straight...
The recomended elevator throw was 10 mm. I think I have 7-8 MM. Would the plane being tail heavy cause this???
I have .46 on this thing and wow!!the power is there.. It is nice and quiet because i don't have to take the baffle for more power.
It is a very smooth flying plane. It is an ARF and with the big fx on the front there is some tail weight. When I bought the plane it had about 1 1/4 oz of weight in the tail because the previous owner had a .46 on it. When I install the fx, I had to add about 3/4 oz more to the tail. I did have a hard time balencing it. The CG was at 4.33in. If the nose is much heavier, should increase the elevator throw more than the recommended??
Any suggestions?????
Thanks!!!
Thanks!!!
CA
It sounds like you are experiencing a snap.
The most likely causes are - too much elevator movement or the two halves of the elevator aren't acting exactly together.
With a small aircraft like the Zen 30 it's amazing how small the elevator movement has to be to be adequate.
Watch for a similar snap if you make landing approaches too slow as well.
-David C.
-David C.
