What is the ABSOLUTE BEST PROP
CA
i am an owner of a .91 four stroke engine. i am looking for the BEST 14x6 prop that is available, below $30. i am looking for thrust. noise is tolorable. i would also prefer less vibration, but it is not necessary
My Feedback: (182)
Up to $30 for a 14x6 prop...
It's obvious that you are willing to spend more money on props than I am...hmmm...
I prefer APC ($12) and B-Y&O ($8) The B-Y&O is a wooden prop available from www.brodak.com
Of course there are the exotic brands, too...buy'em if you wonna.
CA
unlimited vertical. here is why i am specifying 14x6: i can't go lower than that because my plane is rather heavy, and won't fly at those low speeds. plus, even if it didn't, i would look really stupid putt-puttin by at 20 mph. where would i find a graupner prop? i already have an apc on order.
What you want is a Graupner 13.5 x 8 They are outstanding on a 91 4-stroke, and will suit your Cap very well. (and under 10 bucks)
http://www.hobby-lobby.com/grprop.htm#2%20Blade
CA
where would i find boly props? carbon fiber may be the answer. do any ofyou guiys know where to find a good carbon fiber prop?
My Feedback: (19)
bolly props
http://www.bollyprops.com/clubmanintro.html
Not sure they make CF props that small. 18-6 is the smallest Ive run across in mejlik
I dont think that is what you want for a 91 anyway. CF props are usually a bit heavier and no prop on a 8+ lb plane with a 4 stroke 91 is going to turn it into a hovering machine
I have a 60 size Kaos that weighs about 7.75 lbs. It has good speed and very good vertical with the bolly clubman, but not unlimited with a saito 91
My Feedback: (132)
www.desertaircraft.com
They carry Bolly, Mejzlik, Menz & Air Models props. However most of these manufactures cater to larger sizes.
CA
i just got my apc 14x6. it worked jsut as well as the master airscrew, but not better. in that case, i will stick with the ma prop tdo i don't have to modify my spinner.
IN
prop
I've got four planes with 91 four strokes. Two TF warbirds one 10.5 lbs one 11.5 lbs both fly well with Graupner 14-7 props. A Citabria @ 9 lbs flys with a APC 14-6. A CAP232 @ 8 LBS. with an APC 15-4W. Very good vertical, the W is for wide, not the thin sharp typical APC it actually resembles the Graupners.
