Reload this Page >
Help with a new plane doing loops.
Old 07-02-2003, 05:48 PM
Skyfoxx
Default Help with a new plane doing loops.
Hello,
I have a zen 30 with a .46 fx installed.
The plane flys great but when I do a loop the plane will go straight up and will not complete the loop. It will bail out.
Almost like it don't have enough power to flip the plane over a complete the loop???Any suggections
Old 07-02-2003, 06:08 PM
FLYBOY
FLYBOY's Avatar
How is your center of gravity? Is the horezontal stab true with the wing? Is the wing straight? Thats where I would start looking. How much throw do you have in the surface?
Old 07-02-2003, 06:25 PM
Skyfoxx
I believe everything is good the wing is on straight...
The recomended elevator throw was 10 mm. I think I have 7-8 MM. Would the plane being tail heavy cause this???
Old 07-02-2003, 08:27 PM
FLYBOY
FLYBOY's Avatar
If it was extremely tail heavy, it might, not enough throw might comboed with it. How does it fly other than that? WIll it loop if given more speed?
Old 07-02-2003, 10:48 PM
Skyfoxx
I have .46 on this thing and wow!!the power is there.. It is nice and quiet because i don't have to take the baffle for more power.
It is a very smooth flying plane. It is an ARF and with the big fx on the front there is some tail weight. When I bought the plane it had about 1 1/4 oz of weight in the tail because the previous owner had a .46 on it. When I install the fx, I had to add about 3/4 oz more to the tail. I did have a hard time balencing it. The CG was at 4.33in. If the nose is much heavier, should increase the elevator throw more than the recommended??
Any suggestions?????
Thanks!!!
Old 07-02-2003, 11:18 PM
David Cutler
David Cutler's Avatar
It sounds like you are experiencing a snap.
The most likely causes are - too much elevator movement or the two halves of the elevator aren't acting exactly together.
With a small aircraft like the Zen 30 it's amazing how small the elevator movement has to be to be adequate.
Watch for a similar snap if you make landing approaches too slow as well.
-David C.
Old 07-03-2003, 01:48 PM
Skyfoxx
I did not think of that, I will have to check it out,
Thanks Dave
