Help! Wing hold down broke on Big Stik 60
Reply
Old 07-03-2003, 01:29 PM
68Chevelle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help! Wing hold down broke on Big Stik 60
During a slight mishap on landing my GP Big Stik 60, my wing clipped a culvert and tore the front tab on the wing hold down. The nylon bolts at the rear did not break. The little tab on the front of the wing where it locks into the front fuse sheared off and tore the former. I am going to rebuild the former and was wondering how I can fix the wing tab. Should I do surgery on the wing and insert some hard blocks and insert a dowel? I don't know what or how to line up the dowel with the block I am inserting in the fuse former. Any suggestions???
68Chevelle is offline
Old 07-03-2003, 01:34 PM
FLYBOY
FLYBOY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would open it up, put ply plates in with triangle stock on them and put plates under the wing in the fuse with triangle stock bracing and use wing bolts up there. One on each side. I have it that way on mine. Works really well.
FLYBOY is offline
Old 07-03-2003, 02:52 PM
Spaceclam
Spaceclam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would get a wing kit, sence performing major surgery on a very critical part of the plane that way is a little risky.
Spaceclam is offline
Old 07-04-2003, 04:14 AM
Taildrager-inactive
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did the same thing a couple of times on my stick, just build it back with bracing, and if all else fails dowel rod like a trainer and 12 #64 rubber bands.
Taildrager-inactive is offline
Old 07-05-2003, 01:50 AM
FLYBOY
FLYBOY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Risky?
Have you only built ARFs? It is a very easy fix. Shouldn't take more than an hour start to finish!
Theres a lot to be said for knowing how to fix a plane. You don't just replace it if the covering tears or a minor part needs replacing. I have done major surgery to many planes for many people. This is very minor.
FLYBOY is offline
Old 07-05-2003, 12:07 PM
DBCherry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I made the same repair to a relatively aerobatic plane of mine last fall. Flying fine, and I haven't pulled the wing off yet.
Dennis-
DBCherry is offline
Old 07-05-2003, 03:15 PM
68Chevelle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks everyone! I think I'll go with the 2 screws up front. Sounds like it would be stronger and less stressful on the center wing.
Thanks Again!!!!
