flycamone2
flycamone2
hi. i just purchased a flycamone2 and was wondering what would be a good sd card to get for it. i got it so i can get some footage on the rc cars and also as a helmet/hat cam when im hunting and riding the quad. im normally a car guy but i posted here because i thought you plane guys might have more experience with the camera. i just tried it out with my cheap walmart sd card that i use in my digital camera and the quality leaves a lot to be desired. i have heard that i need a card with 10mb/s or 20mb/s and my card is only 5mb/s. just wondering what you guys are using. thanks
NY
RE: flycamone2
If it takes SD cards, this one is rated at 15mg/sec http://www.newegg.com/Product/Produc...82E16820171346
NY
RE: flycamone2
If it takes SD cards, these are rated at 15mg/sec
http://www.newegg.com/Product/Produc...82E16820171347
http://www.newegg.com/Product/Produc...82E16820171348
and these are rated at 20mg/sec
http://www.newegg.com/Product/Produc...82E16820134865
http://www.newegg.com/Product/Produc...82E16820134866
NY
RE: flycamone2
yes, the higher the better. I'd go for a little more money with the ones rated at 20Mb/sec since you said you saw a quality problem (what was it by the way) with the card you have. On the other hand, for 11 bucks for the first card listed, I think you'll also be fine with the 15Mb/sec 2GB card personally, as it meets the 10-20mb/sec rating you specified as well.
RE: flycamone2
ill probably go with the 20mb/s. the quality problem was when i was messing around with it in the house. it seemed like it didnt do so well in low light. i took a video with it mounted on my atv helmet and it turned out pretty good but im also going to be using it as a barrel cam for duck hunting and i want it to be good in low-light conditions also. thanks ill check those out and ill post up a vid showing the quality.
