Tilted vertical fin, will that hurt.
Reply
Old 07-04-2003, 12:23 AM
JW Walker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Tilted vertical fin, will that hurt.
I put together a LT 40 and to make a long story short the vertical fin is about 3/16 tilted to the right at the top. Will this hurt the flying of the plane, or will trim be adequate to compensate for this. Or for that matter will it make enough difference, that I should just cut it off and redo it. ? JW
JW Walker is offline
Old 07-04-2003, 12:28 AM
dickj
dickj's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
IT will fly ok just remember to next time use a square of some type. YOu could cut the fin loose and straighten it up and then use some 3 cornered stock to epoxy the tail and fuse together straight.
dickj is offline
Old 07-04-2003, 12:37 AM
FLYBOY
FLYBOY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wouldn't mess with it. You probably won't notice it. Not a huge deal on that plane.
FLYBOY is offline
Old 07-04-2003, 01:01 AM
_kearney_
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with fly boy. I had the same problem with my horizontal fin. I fixed it however it still flys the same. However with the lt40 has a weak vertical fin. I have seen it break off in mid-air. 3 corner stock could give the fin some extra strength. well good luck!
_kearney_ is offline
Old 07-04-2003, 01:09 AM
JW Walker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the reply`s folks. JW
Old 07-06-2003, 04:47 PM
tunnelvishon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In any plane that "is" sensitive to this condition, trimming will work, but only for that particular speed your flying. As the speed increases or decreases your trim will have to change accordingly.
tunnelvishon is offline
Old 07-06-2003, 09:37 PM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On a trainer, you will not see that difference in flying.
Enjoy your plane!
Geistware is offline
Old 07-07-2003, 10:05 AM
seaplane
seaplane's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with Brandon16. Although the LT-40 is a great plane, the verticle stab joint is weak. I have seen 2 break in mid air. Use the triangle balsa on each side of the joint as was suggested. Also, don't worry about the angle, it will fly OK.......Seaplane
seaplane is offline
