Cline Regulator
TX
Cline Regulator
I've installed the Cline Regulator on my UCD3D with a Saito 100...the question is in regards to the two "press on" type fittings on the regulator itself. Do you adhere them in any way or just push them on hard and be done with it? They seem like they might come off after some time vibrating around the engine area.
NC
Cline Regulator
Just push them on, do not glue. The only time I have ever had one come off was when I crashed the plane. Plus, you need the flexibility to move them into different positions.
