DuBro Tank
DuBro Tank
Hi all, I recently completed an older Falcon 56 kit. I have installed a Dubro 8 oz tank on its' side in the aircraft. One of the guys at the field is appalled and says it will cause problems. For the life of me I can't see what. Isn't the idea of a clunk tank that it will supply fuel no matter what its' orientation. I await your wisdom.
Cheers
Gord
Cheers
Gord
RE: DuBro Tank
Hi!
He can't have been in this hobby long if he thinks mounting a tank on its side is something to be appalled about!!!
Just go ahead! As long as you mount the tank with the fuel pick-up tube to the bottom and vent at top ...it work just fine.
A tip!
Use two clunks (one to silencer pressure and one to carb ) that way you get a Uni-flow tank ...and you get a more even fuel flow to the carb.
A tip!
RE: DuBro Tank
Thanks guys,
The width was exactly why I did it. It fit beautifully on its' side but didn't have a chance the other way.
Cheers
Gord
Cheers
Gord
My Feedback: (-1)
RE: DuBro Tank
ORIGINAL: jaka
Hi!
A tip!
Hi!
A tip!
AR
RE: DuBro Tank
Gray Beard:
I'm guessing that what Jaka is doing is running a line from the muffler to a line with a clunk on it. The second line with clunk goes to the carburetor. The third line, vent, is simply open to the air or maybe has a line running to some place that is open but protected from dust, etc. That way, muffler pressure is introduced directly into the fuel because the clunk will keep the line submerged. With this setup, I guess the tank could be filled from the carb line or the muffler line. Just a guess. It could be all wrong.
RE: DuBro Tank
On second thought, wouldn't exhaust gas directly in the fuel cause bubbles? I'm confused.
http://www.fraserker.com/heli/uniflo...flow_works.htm
Ed S
My Feedback: (-1)
RE: DuBro Tank
ORIGINAL: JollyPopper
Popper, if you have an open vent in your tank any pressure being pushed in would just flow right out the opened vent. My OS pumpers require an open vent because they suck the fuel from the tank. My YS engines require a closed system because they use positive pressure and pump about 7 or 8 pounds into the fuel tank, don't run fer beans without that pressure in there!!
As for bubbles from the pressure, the fuel would never notice it. You would get more bubbles from vibration and sloshing around durning flight. The anti foaming agents used in fuel these days seems to work pretty well.
Wish someone would put that in flight video of the fuel tank showing what happens during flight on a sticky!!! It's a real eye opener.
I will get my tank set up something this week and give it a try.
RE: DuBro Tank
You can't run any clunk line to your muffler with an open air vent... unless you want your fuel to siphon into your muffler and fill it up.. and run all over the table. That's the difference in the "uniflow" set-up, and a coventional 2-clunk set-up. With the uniflow you only vent the tank for fueling/defueling... other then that.. the vent stays closed.
RE: DuBro Tank
ORIGINAL: Gray Beard
I read it, I understand the thinking, just can't see it as a lot better then the normal three line system with the pressure being pushed in from the top. I will give it a try with one of my planes/tanks I have been having a problem with. I was going to go to a bubbless tank but I may as well see if this works for me or not.
That same pressure is pushing fuel into the carb on your engine, but as it reduces due to the tank emptying the pressure from the exhaust has more impact which counters the reduction in impact of the fuel's inherent pressure. It's not about creating more pressure, but rather keeping the pressure constant so the mixture doesn't vary as much as the tank empties.
Having said that - I don't use uniflow systems as I like ezy-fill fittings (despite the popular opinion against them on here), and I really don't want to install a tank vent AND the filler. It's usually safer and easier (in my opinion) to have a larger than required tank and land with it still 1/3 full, which not only lessens the impact of reducing pressure but also gives you plenty of scope for aborted landings etc (albeit at the cost of a little extra wet weight). That way I land when I want to, not when I have to.
RE: DuBro Tank
Hi!
The Uni-flow tank is like any other tank! You fill it as usual trough either the silencer clunk line...or through the fuel line that goes to the carb!
As you do you have the vent line open!
When you have filled the tank you close the vent line. Usually I use a 3mm screw for this. See picture below.
RE: DuBro Tank
and having the vent line closed and pressure going into the fluid does not cause bubbling?
AR
RE: DuBro Tank
I'm embarrassed. Of course the vent would have to be closed except when fueling up. What good would it do to put pressure in the tank if it had an open vent? Not the first time I ever said something stupid before I thought it through.
