Antifreeze Cleaning Method???
Reply
Old 07-06-2003, 06:00 PM
Jerkey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Antifreeze Cleaning Method???
Has anyone tried doing the crockpot antifreeze method of cleaning an engine? If so I have one question. Would it be better to leave the piston at the bottom or top of cylinder during the process.
Mike
Jerkey is offline
Old 07-06-2003, 09:36 PM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used it and don't really see any difference so long as you get the solution in the piston at the top.
Geistware is offline
Old 07-07-2003, 05:43 AM
Carlos Murphy
My Feedback: (72)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Crock Pot
I've used this method for years, works well.
I usually remove the back plate, carb and glow plug and pay no attention to piston position.
Check out page 152 of the new RCM (August) for an article on this subject.
Carlos Murphy is offline
Old 07-08-2003, 05:56 PM
Goku
Goku's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've never heard of this....
how exactly does it work? you soak an engine in heated antifreeze to clean it? How long (on average) do you soak it?
Ho much do you heat the antifreeze?
Goku is offline
Old 07-08-2003, 07:15 PM
DBCherry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Doubt piston position matters.
Goku,
Yes, heat antifreeze in a crock pot, let the engine sit in it overnight. Works well, just DO NOT use the crock pot for food EVER again!
Dennis-
DBCherry is offline
Old 07-08-2003, 07:24 PM
Goku
Goku's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah... I can see how the wife probably wouldn't go for that...
Thanks!
Goku is offline
Old 07-08-2003, 11:16 PM
bullseye000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I cleaned 3 engines that were covered in brown varnish. It was so bad I thought I would have to junk them. I was skepticle about the antifreeze trreatment but figured what did I have to lose. I searched for all of the threads on the subject and followed the procedures outlined in the posts. I worked better than I ever imagined. One engine was so bad I had to soak it for about 5 days, but when it was done the engine looked almost new.
bullseye000 is offline
Old 07-09-2003, 12:25 AM
Crash_N_Burn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You know, I bought the crock pot, the aluminum antifreeze and was set to do the deed last weekend.
Instead, I opted for carb cleaner and a small stainless steel wire brush.
Wow! Looks as good as new and only took about 15 minutes.
The downside is the engine is like my body...Clean on the outside and, well, not so clean on the inside.....
Crash_N_Burn is offline
Old 07-09-2003, 05:09 PM
visioneer_one
My Feedback: (506)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Antifreeze.
I'll link to my writeup rather than reposting it.
http://www.rcuniverse.com/showthread...698#post777318]
visioneer_one is offline
