Reload this Page >
Servo Horn and Surface Horn configuration, your thoughts please.
Reply
Old 07-08-2003, 11:58 AM
Blackie
Blackie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Servo Horn and Surface Horn configuration, your thoughts please.
I have a question concerning rod placement on the control horns. Correct me if I am wrong, but positioning the control rod on the servo horn furtherest from the servo and closest to the surface on the surface horn give's the longest throw right? Would it reduce stress on the servo if I reversed the rod position on both ends, moving the rod closest to the servo and furtherest from the control surface on the horn? and would I continue to maintain the same throw by doing so?
Hope that made since.
Blackie
Blackie is offline
Old 07-08-2003, 12:14 PM
Dsegal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
> give's the longest throw right? <
Yes, you have it right. I am not an engineer, but either of the configurations you suggest will have to do the same amount of work for a given control surface deflection so I don't see that there is any difference in load on the servo.
Dave Segal
Dsegal is offline
Old 07-08-2003, 01:30 PM
ChuckAuger
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Out on the servo/ Close to the surface gives more throw, but the surface has the mechanical advantage and can cause the surface to flutter.
If reversed.. In on the servo/out on the surface now the surface won't move as far and the servo has the advantage. This is a much stronger setup, but at the cost of surface throw.
This is the paradox of getting large control throws without flutter. What it boils down to is for the large surface movements, you need strong servos so you can move the connection out to the end of the servo arm, even run very large servo horns so you don't have to hook the linkage very close to the surface, and very slop-free linkage so you eliminate any slop that can develop into flutter.
ChuckAuger is offline
