6 volts
Old 01-25-2010, 10:35 PM
ES CONTROL
Default 6 volts
Buying a U can Do 61, which is cheaper, going to 6 volts or buying a hundred dollars worth of servos? Is going to 6 volts as easy as buying a battery and plugging it in?
Old 01-25-2010, 11:15 PM
blvdbuzzard
Default RE: 6 volts
For me it is. But then again I fly Airtronics. I had some Cirrus CS-601 servos and Cirrus CS-702 servos in my Formula 3D. They work at 6v without any problems.
Dru.
Old 01-25-2010, 11:35 PM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Default RE: 6 volts
There are only a select few servos that are not suggested to run on 6 volts. I have one 4.8v battery left over from when I started out, but everything from now on will run at 6 volts (or more).
Yes, it is as easy as buying a 6V battery and plugging it in.
I have had great luck/success with the Hobbico Hydrimax 6V 2000mah batteries. Should be about $20-$25
Old 01-25-2010, 11:45 PM
1fishnfool
My Feedback: (42)
Default RE: 6 volts
Ok,funny I should find this post,as I have a similar question about 6v.As said,almost all servos are OK with 6v.Now,as far as regulators go,I have seen them anywhere from 20 bucks to 80 or so for adjustable.Now this is my question,if I am going to use it in a sailplane,do I need to buy a regulator,or can I just run one of my 7 dollar speed controlls with bec?It weighs about the same as the common sense 20 dollar regulator.It makes sense to me.
Old 01-26-2010, 12:13 AM
nmking09
My Feedback: (61)
nmking09's Avatar
Default RE: 6 volts
Regulators are used for 7.4V LiPo or Li Ion packs. Not 6V Nimh. To go to 6V just buy a pack and plug it in. You will need slightly more battery capacity than you would at 4.8V, but not too much more (20% more would be enough).
If you are running LiPo's: ESC Bec's are usually pretty cruddy. The castle CCBEC is a machine and weighs practically nothing. I used one of those on my 50cc Cap with 6 digital, high performance servos, and it never blinked. Believe me, I thoroughly tested it.
http://www.youtube.com/watch?v=BA9g2WfBK8s
Old 01-26-2010, 05:44 PM
ro347
My Feedback: (13)
Default RE: 6 volts
If your servos are 6v capable...then yes. its that simple.
Old 01-27-2010, 11:47 AM
jaka
Default RE: 6 volts
Hi!
99,9% of all servos work on 6Volt so it's non issue!
