is this a real futaba controler?
Reply
Old 07-11-2003, 12:03 AM
zhanx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default is this a real futaba controler?
i got this in kuwait, is this thing real?
on the front it says SKYSPORT and under that it has Digital Proportional then T4YBF <- not a V but a Y, in the lower left hande corner is the freq. which has 79 on the front and 40.790 inside. my second question is: will i have to change the crystal for state side use?
zhanx is offline
Old 07-11-2003, 12:07 AM
zhanx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default the back
on the back its says made in china.. hence why i think is a not knock and not the real thing and gives a number 02013, along with a 6 pin din that is square for the trainer port. Should i fly with this thing or try to return it? I tested it with the servo's and everything seems to work fine. but i am leary of using it
zhanx is offline
Old 07-11-2003, 01:00 AM
Tall Paul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I saw a new Futaba at the LHS which has a 6-pin rectangular trainer port in the rear as you show.
Other than "return to Futaba" for a frequency change once back in ConUS, I'd fly it.
Or pass it on to someone staying there...
Tall Paul is offline
Old 07-11-2003, 01:21 AM
Live Wire
Live Wire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like the radio tower hobbies sells under there name, has lights not a meter.
Live Wire is offline
Old 07-11-2003, 01:35 AM
DBCherry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think it's a genuine Futaba, but overseas frequencies are way off from here in the states. I doubt it can be used here at all.
Dennis-
DBCherry is offline
Old 07-11-2003, 01:44 AM
Live Wire
Live Wire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just checked it is a System 3000 Tower. Or made by same Co.
Old 07-11-2003, 02:56 AM
zhanx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default i think i found it
http://www2.towerhobbies.com/cgi-bin...I=LXCUM2**&P=0
zhanx is offline
Old 07-11-2003, 08:17 PM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It would be a knockoff. ALL Futaba R/C transmitters say "FUTABA" on them very plainly. They do not have a manufacturing plant in China, as far as we know.
A Tower Hobbies transmitter would also say "Tower Hobbies" prominently.
If the transmitter is a 40 MHz unit, it's not likely it can be converted to 72 MHz. There are too many circuit differences with that large a band change.
Bax is offline
Old 07-11-2003, 11:05 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Irrgardless who made it you will never be able to get a proper band change to to the proper band And it is a low value unit to start with, certainly not worth messing with. Yes Futaba and all the majors make cheapy entry radios. Best to advertise it and properly identify the band it is on so perhaps someone traveling to that part of the world could indeed use it.
Hard to tell from the photo but it looks as though it is a mode 1 unit which is used in this country by few and that fact will make it difficult to find an instructor to work with you.
John
JohnBuckner is offline
Old 07-12-2003, 06:15 AM
zhanx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the info everyone. i guess i'll change out when i redeploy statside
zhanx is offline
