clunk problems
Reply
Old 07-11-2003, 04:59 AM
f4ucorsair
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default clunk problems
Here's the problem.
I have a ROSSI 40 and it sucks the fuel fast. So in a loop or a dive it runs the line emty. I just bought this motor and this is the first time I've tried to fly it. In all other flight (level,nose up,side to side) it's good. Any thoughts would be great.
f4ucorsair is offline
Old 07-11-2003, 11:31 AM
DBCherry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try larger diameter lines? Unless the clunk is stuck at the front of the tank, I doubt there's anything you can do to the clunk that will help.
Anyone else have thoughts?
Dennis-
DBCherry is offline
Old 07-11-2003, 11:41 AM
tinman
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default .
sounds like the clunk line is too short maybe?
tinman is offline
Old 07-11-2003, 02:23 PM
f4ucorsair
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I went out this morning to try larger lines the engine only run for 2 sec in the nose down (line emptied). I'm thinking a header tank might help, like on the choppers. Any thoughts?
Old 07-11-2003, 02:52 PM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was going to suggest a header tank. That should solve the problem.
MinnFlyer is offline
Old 07-11-2003, 03:00 PM
bob_nj
My Feedback: (62)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where is the centerline of the tank in relation to the centerline of the venturi?
bob_nj is offline
Old 07-11-2003, 03:19 PM
Kaos Rulz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could you be running overly-rich?
Kaos Rulz is offline
Old 07-11-2003, 03:39 PM
Tattoo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the air or on the ground? On the ground the fuel will run forward and there will be no fuel available, especially if you installed thicker lines and the clunk is staying to the rear of the tank (where it's supposed to stay).
When I started running Norvel engines in my combat planes, I began having the same problem. It was frustrating at first, but then (long story short) what was actually happening was the thin chincy fuel line supplied by the tank manufacturers was sucking flat and closing off. I replaced the clunk line with the same stuff I use for external line and have not had a problem since.
Tattoo is offline
Old 07-11-2003, 05:20 PM
f4ucorsair
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I was to use a header tank what size should i use? Also, how should I hook it up. Where should the header tank be put?
Old 07-24-2003, 06:35 PM
f4ucorsair
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I figured out the problem. The fuel tank was sitting too low. Thanks for the help.
Old 08-06-2003, 07:39 PM
The Gimp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fuel Tank
Try placing a straw over the the fuel line in the tank to keep it from getting stuck fwd.
The Gimp is offline
