restarting 10 year old build
Hello I have a Question for you guys. I have been given a Top Flight F4U, this kit was started in 2000 and now I have it. The Fuse is complete and sheeted no fin or stab, the wing is framed up but not sheeted. I have this wing Jigged to the building table with Zero incidence in Center and Both wing tips at Zero Wash out, it's not going to move.
Now here is what I am wondering about, Should I do anything to wet/dampen this wood and dry slightly to bring some moisture back to it before sheeting and then Glassing this wing and fuse for that matter?
Thanks in advance
-Tracey
Thanks in advance
-Tracey
My Feedback: (-1)
RE: restarting 10 year old build
If you are going to use any CA glue it is a help to get moisture back into the wood, for glassing or using epoxy you need not bother. When I get old kits I have the kit box in the bathroom with the box opened and for the next few days the wood gets some moisture back in it from just the steam when we shower. It doesn't take much.
So what's your wife think about airplane kits in the bathroom?
Mine got a little irritated when ours was full of pepper plant seedlings once. It tried to explain that it was the SW corner of the house and therefore theoretically the warmest room but she didn't seem to care.
My Feedback: (-1)
ORIGINAL: ChuckW
ORIGINAL: jaka
Hi!
Why would you like to get the balsa damp???
Just get some wash-out in those wing tips and build!
Hi!
next question is how much washout at the tips?
Thanks guys keep it coming
My Feedback: (-1)
Misting will cause warps, the steam from the shower with the kit sitting there in the bathroom only replaces some moisture in the wood to help CA glue to react. No CA then no reason for putting moisture back in the wood. You should be able to get the instructions from the Tower web site, the kit is still being made. Everything you need to know should be there.
Thanks for the help guys. All joints have been rechecked and Thin CA added to all joints and I have sheeted wing with 1.5degree of washout per tip, LE down 1.5 degree while center is zero
Thanks again
-Tracey
Thanks again
-Tracey
