Throttle Problems
IA
Throttle Problems
Hey all, my Sig Somethin extra is ready for the engine mounting. PROBLEM!!!! My throttle on my saito 56 arm is right inline with the engine mount, and no way to get around it. Any tips????
RE: Throttle Problems
It would be better with a picture to see what the issue is but the center screw on the throttle can be loosen to reposition the throttle arm they also sell longer arms (likeservo arms) in assorted lengths. You can also try to use a flexable linkage rod to the arm. If you could post a picture it would be better to know if the issue is a side clearance issue or a height issue.
GA
ORIGINAL: LargeScale88
My Feedback: (9)
I have a Saito 72 on mine. I have the throttle arm next to the cheek block on the left side of the plane. I marked the area around the arm, removed the engine, then carved out a relief in the wood. The cheek is thick in this area and gave plenty of room. Then I used a solid metal pushrod with a Z bend on the throttle arm end. I installed this on the carb and then feed it through the firewall as I installed the engine. I have a slight bend in it behind the fuel tank to line up with the servo arm. Then I used an EZ conector to attach it to the servo arm and give me some adjustment.
David
David
This is a standard, upright Somethin' Extra firewall. The location of the throttle control is within 1/16" of the side of the interior formers. I ended up pushing the control tube further away from the fuse side. My engine is an OS46 AXwith the front-mounted carb with the throttle arm on the front right. The Saito 56 has the carb located at the back with the throttle arm on the left (pilot's left) of the cylinder. Can you rotate the carb so that the throttle arm is on the right? If so, use a throttle wire routed through the SIG-specified throttle control location, add a 180 degree bend close to the cylinder to route the wire back towards the firewall and then add a 90 degree bend in the wire to connect the control wire to the carb's throttle arm.
I've added a pic of my Big Stik 40 with a Saito 82 mounted. Notice that the high speed needle exits to the left side of the engine with the throttle arm to the right.
***** trust me when I say I'm getting REALtired of RCUloading images incorrectly.
