Black Horse Home Run Landing gear problem
Reply
Old 07-15-2003, 01:22 PM
njl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Black Horse Home Run Landing gear problem
I had to make a dead stick landing with my Home Run pattern ship onto a slightly rougher part of the field and the landing gear wire on the Right hand wing bent back and ripped up a small section of the wing. (Were only talking 3 - inch long grass). I've not had a chance to remove the covering and inspect the internal damage yet but it looks to me like the design is weak and needs some additional strengthening. This is only the fifth landing with this plane and non of them have been hard landings.
Basically each main wheel is attached to a metal rod that bends 90 degrees and runs along the wing for four inches or so before bending 90 degrees and going up into the wing. There are two metal plates screwed over the wire to keep it pressed onto the wing. The bending moment of the wire is against the wing internals. The wing is a balsa type construction, not foam.
Any one else had this type of problem? Any ideas how I might beef up the support for the main landing gear on this plane?
Also does anyone know what the covering material used on these kits is called so I can get some to re-cover the bottom of the wing once I've repaired it.?
Thanks for any advice,
Nick
njl is offline
Old 07-15-2003, 03:28 PM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Surrounding the Landing Gear Blocks with a "U" shaped piece of plywood would work well. Otherwise, just some triangle stock forward and aft should hold it.
MinnFlyer is offline
Old 07-15-2003, 07:21 PM
DBCherry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice graphic as usual Mike! And the ply plate should help a bit.
Generally speaking though, Most planes I've had with this type of gear mounting will be damaged by running off into tall grass, or a hard landing. They're built to fly, not crash. (Not to say that you did.)
Do you have wheel pants on it? They'll add to the problem substantially.
Dennis-
DBCherry is offline
Old 07-15-2003, 09:20 PM
njl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the tips guys.
I've not got wheel pants on the model but I had upped the size of the wheels to 3 inches to help with ground handling as I fly from a grass strip. (Shared with full size planes)
Nick
njl is offline
